HTML template for your SSTVcam (English)
Geplaatst: 26 mei 2008, 01:12
Here's an example template if you want to use FTP widget (or a similar FTP tool - like DM780) for uploading your images to a webserver. But nobody can view your images without a webpage. This is one!
Probably you like it :) Here's the download:
PE1RQM_SSTVcam_FTP_widget_template2.2.zip
(26.56 KiB) 2152 keer gedownload
Preview:
Or have a look at my own SSTVcam...
You only have to modify some of the path's and names in the code. I made instructions in the html code, so that wouldn't be that hard I think.
If you have suggestions or questions, feel free to contact me; pe1rqm at amsat dot org, or use this forum for your reaction.
Don't forget to come back sometimes, because I will add more templates in the future. Also updates.
Re: HTML template for your SSTVcam (English)
Geplaatst: 09 jul 2008, 22:48
Updated to version 2.2.
Better for old IE6. One issue left for IE6: Text under the table is sometimes not visible... Don't know why. Have to figure that out. Anyone tips?
